1987 Mercury XR2
4bigbass
Motor will not go in reverse,goes in forward fine.Took shift linkage loose and operated manually,forward and neutral works fine,reverse on works if I push in on prop.
Inspection is required.--------Found any water in the gearcase ?------What is end play on the shaft ?----------Is the big nut on the bearing carrier in good shape / tight ?
