jeff.sheard
Hello All,
I'm troubleshooting my recently purchased 8 year old 5hp 4stroke nissan outboard due to no extra power output after about 60% throttle while in gear. It used to bog down and stall out after 60% throttle and then I cleaned the carb and got brave and cleaned the fuel pump too. Now it won't stall anymore but it won't get any more power past 60% throttle. I noticed the diaphragms in the fuel pump seemed a little too stiff (like not as rubbery as they once should have been). And I read in this thread a guy saying that a marginal / bad fuel pump would limit top speeds and not idle speeds (the engine idles just fine).
On my last run out...I tried pumping the ball on the fuel line a few times while at full throttle. Well about 2 times out of 5 times trying that...the boat just TOOK OFF...faster speeds than I'd ever seen before...sea state wasn't the greatest so I had to turn her down each time she took off like that to avoid going airborne. But since then I haven't been able to reproduce those speeds/RPM.
So fuel pump or carburetor problem? I bought a pump for $40 and it should arrive in a week or two...Crossing fingers that will fix the problem because the cheapest carb I have found will cost me about $200 CDN with shipping.
I also read in that previous thread that the carburetor assembly for the nissan 6hp (3R4032001M) will fit in the 5hp and give 20% more power. I think I'd like to try this out. Anyone here done that or is familiar with that?
Thanks very much for your time and expertise.
Cheers,
Jeff.
Cheers,
Jeff.
