Results 1 to 2 of 2
Thread: Using Water
  1. #1
    Default Using Water
    I have a Marine Power 7.4 Vortex (MPI) With a Hamilton Jet.
    My question is that I am using a little water and I cant see where it is going I use about 1 1/2 gallons of water every day and it isn't going in the bilge as far as I know. Any ideas as to where it might be going.? Or is there some way to trace it down.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,878
    Default Re: Using Water
    Going down the path that the MPI is FWC'ed and the reference to 'water' is inferring coolant, I'd suspect it is going out the exhaust....if it is FWC'ed, then get a coolant pressure tester...
Similar Threads
  1. Replies: 0
    Last Post: 06-24-2013, 05:17 PM
  2. Temperature rating for 440 chrysler thermostat raw water cooled (fresh water)
    By KavaKava in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-04-2013, 07:17 PM
  3. tohatsu m40d new water pump losing water before it gets to upper part of motor
    By Joel Caillouet in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-06-2011, 01:09 PM
  4. Bravo , low water flow to sea water pump. Possible water fitting?
    By jon_allen in forum Mercruiser Sterndrive Forum
    Last Post: 08-05-2011, 02:18 AM
  5. Best way to clean massive salt deposits off water pump housing, water ports.
    By rixter66 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-10-2011, 02:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
