Results 1 to 6 of 6
  1. #1
    Default ZF Hurth rattling in nuetral
    2002 ZF Hurth 450-A2, 2.03:1 ratio. Shifts fine, no noise in gear, but there is a distinct rattle in nuetral. Paired with a PCM 350. I googled it, looks like it could be a Damper plate.
    Anybody have any experience with this problem?
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,002
    Default Re: ZF Hurth rattling in nuetral
    Make sure it is firing on all cylinders. One cylinder down and it will rattle.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    Chris is right on the money, if engine is not running 100% smooth, noise will show up in tranny at idle. Bad plug wire, bad plug, etc.
    MJK
  4. #4
    Maraian, did you ever resolve it?
  5. #5
    Not really. The PO claims to have replaced the damper plater ( a very common cause) prior to purchase ( with pictures). But it still makes noise. After talking with many others with same tranny, this seems to be very common and is not really considered a problem. Appearently the ZF recommends using a thicker oil (10w40, or something similar) to quiet it, but it's not really an issue other than an annoyance, so I haven't done anything.
  6. #6
    Quote Originally Posted by Docksidemarineservices View Post
    What's the best way to make sure firing on all cylinders?
    I did a compression check, it was good.
    i pulled all the plugs and they all looked the same.... black, a couple where wet ( with gas I think).
    i used a spark indicator light to make sure the dizzy was putting out.
Similar Threads
  1. Hurth zf25
    By Malaya in forum Marine Transmissions and Reverse Gears
    Last Post: 08-05-2014, 12:31 PM
  2. ZF Hurth tranny noise need help.
    By Floatation Device in forum Marine Transmissions and Reverse Gears
    Last Post: 11-10-2010, 12:57 PM
  3. Noisy Hurth 630A
    By LeisurLee in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 09-15-2010, 09:31 PM
  4. Hurth V Drive
    By kevin_z in forum Crusader Marine Engine Forum
    Last Post: 04-29-2010, 09:53 AM
  5. Hurth V Drive
    By DavidJensen in forum Archive 2003-2007
    Last Post: 08-24-2002, 02:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
