1984 70hp johnson no thrust power
veteran81
I need help my johnson runs out of the water but it will not run in water, it stalls. Carburadors have been Re built. Any suggestions?
Thanks,
Veteran81
Very common issue.--------Very common for folks to pick on the carburetors first too.----------On the trailer the motor does not have to do any " work " and will sound fine on 2 of 3 cylinders.------------------So check compression first.------Then see if you have spark on all 3 leads.---Does spark jump a gap of 3/8" , yes or no ?
First of all let me thank you for taking interest in my problem.
Compression is 128 on all 3 pistons. I didn't check for spark. I just removed the lower unit to change water pump and changing seals. I'll putting it back together this weekend. Based on your opinion what could be wrong?
Check and adjust engine sync between the timing advance and throttle opening! Do the carbs open at exactly the same time? Exactly how are you adjusting the slow needles?
