Just got my boat back from shop. Broken off reed valve. Anyways, prior to the incident that most likely broke the reed valve off, my little 15hp ran great. It had what seemed like 3 gear positions, reverse, idle, forward. After the shop repair it just has reverse straight into forward. Is this a missing part (start in gear protection?) Or is something out of adjustment? I do know that before the motor would start in gear forward or reverse, or the neutral. While looking at the gear lever that is triggered from the gear shift, it seems to fall into the only two grooves that I can see.
Seems like something that could be cheap and easy to fix on my own. Did a quick search for a part to no avail. Any info on what this may be would really be appreciated.
Thanks!
Thanks!
