Results 1 to 3 of 3
  1. #1
    Default hard start when warm
    I have a 357 merc mag bravo L/V in my22' ,90 ultra with bravo outdrive, anyway when its cold like overnight sit, it'll fire right up with a tap of the ignition, after being on the water for a bit I like to shut it down float and chill for like an hour, go to start it up and it acts flooded, very hard to start but eventually get it started. thoughts? appreciate any feedback.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,101
    Default Re: hard start when warm
    operating procedure....especially if the engine box is 'tight'......
    What I suspect is happening is too much heat!!! do you take steps to ensure proper cool down before shutdown?
  3. #3
    I had the same problem but on a Merc 4.3 TB4 ignition, turned out it was the timing was set at 1-deg BTDC (should have been 8-deg) Just a thought!
Similar Threads
  1. 92 xr6 150 hard to start after warm up
    By randyjtn in forum Mercury Mariner Outboard Archive
    Last Post: 07-20-2009, 12:17 PM
  2. 74L MPI Warm Hard Start
    By djdaigle in forum Mercruiser Sterndrive Archive
    Last Post: 07-30-2008, 10:12 AM
  3. 150 hp XR6 Hard to Start when Warm
    By David Schroeder in forum Mercury Mariner Outboard Archive
    Last Post: 04-23-2008, 09:14 AM
  4. Replies: 0
    Last Post: 08-12-2007, 07:27 AM
  5. Hard to start when warm
    By donmega in forum Mercruiser Sterndrive Archive
    Last Post: 06-07-2007, 05:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
