I've been reading up on all the old threads, since I just got into the bushings for the first time today. One bushing wasn't even there. I assume the previous owner tried running without it. The other bushing was so ate up it came out with a couple taps from the slide puller. The drive shafts are good......the new bushings fit well, with just a hair of play, and I mean a skinny hair.
The area behind the rubber has significant corrosion in both. I cleaned it all out to assess. Fortunately, I don't have the mid-section blowout damage. There is still enough of the bushing housing left to require grease to get a new one in. So maybe I have a chance to repair this.
I'm going to finish getting back to clean metal. Then I'm going to follow with metal primer and one coat of epoxy (as in barrier coat). Finally, I'm going to fill the channels in the rubber with Mystic 6, which is a heavy grease that remains in place and is highly resistant to being washed away by water. And I will grease the shaft at the bushing.
My dealer says if I do this service every 250 hrs, I should be ok from here on out. We'll see.
I can't see any mechanism for water to get to this bushing, so how does it get lubed, let alone flushed? I read where there is a hole in the vertical water shaft, but I don't see it. Maybe it's corroded closed. I'll look closer.
One guy suggested putting in a grease zirt. I like that idea, and might assess how it could be done.
Any ideas?
Any ideas?
