yellcounty
have a 1996 force 40 hp is getting exhaust under the engine hood. seems to be coming up around the drive shaft .
motor came in and was leaking water and exhaust around the adaptor plate , there were also 3 bolt missing from adaptor plate. put new gasket and replaced all bolts with new lock tight bolts from factory . does not leak from there anymore but now getting exhaust coming from around driveshaft sucking it up inside motor cover causing motor to stall at idle. I pulled the lower unit off and the drive shaft housing replacing all the bucket seals, power head gasket, and the rubber by the water pump and even added sealer across it to seal exhaust there. after all that still getting exhaust under hood . I am missing something any ideas .
