i am not sure, not at boat now.what does "acked" mean ?
What transmissions do you have?
Borg warners ?
The, ah, prop will also need changing if the replacement motor spins the other way.
Jeff
I'm confused, if they are Borg Warner Velvet Drives, then why is the input rotation reversible by rotating the pump cover?
The out put rotation on a Velvet Drive can not be changed by turning the pump cover.
If input rotation has to match output rotation then why are the pump covers on the transmission made to rotate?
I'm looking at this wrong some how ?
