Results 1 to 3 of 3
Thread: prop size
  1. #1
    Default prop size
    what is the proper prop size for a 1986 422 chris craft commander
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,242
    Default Re: prop size
    Ayuh,.... What motor,..??
    What drive ratio,..??
    What's the problem yer tryin' to fix,..??
  3. #3
    Quote Originally Posted by bondo View Post
    the boat is suppose to cruise at 22 mph and i only go about 17 mph at 2000 rpm's not sure on the drive ratio, but i have detroit 671's turbo
Similar Threads
  1. Prop size question and off shore style prop on a through hub exhaust?
    By H2oallyear in forum Propeller Selection and Replacement
    Last Post: 07-25-2014, 08:07 PM
  2. What Size Prop should I use?
    By KQQLCAT in forum Mercury Mariner Outboard Forum
    Last Post: 05-07-2012, 08:06 PM
  3. PROP SIZE
    By bream_master in forum Johnson Evinrude Outboard Archive
    Last Post: 06-21-2009, 09:55 PM
  4. Prop install and prop size
    By birdy916 in forum Mercruiser Sterndrive Archive
    Last Post: 06-10-2009, 08:20 AM
  5. Prop size
    By vness in forum Johnson Evinrude Outboard Archive
    Last Post: 11-21-2008, 07:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
