Teleflex Steering Problem
dylZee
Hi all,
I recently bought an old 14ft run about from a guy who was upgrading, he said it had a problem turning in 1 direction.
Had a look today and from what i can see the cable pushes all the way turning the motor full lock in that direction but when the cable is being pulled it only goes about half a turn passed center before the push-pull rod in the tilt tube hits the outer tubing on the teleflex cable not allowing it to turn anymore.
Any idea why that would be happening?
Is the rod supposed to go inside the outer tubing to allow the cable to pull and turn the motor?
if not does that just suggest the wrong teleflex cable has been installed?
cheers,
Dylon
