Results 1 to 2 of 2
Thread: KFL valve issue
    Default KFL valve issue
    I have a 1956 Sportsman with KFL 131 hp engine that
    did roll over several times(has been sitting for ? long time)
    The next day I planned on doing a compression test
    The starter would not roll the engine, I pulled the starter and it did roll
    I attempted to turn the engine with the flywheel and it would roll about 1/2
    turn in either direction and stop solid
    I pulled the head and found several valves stuck open or closed
    all the piston seemed to work properly and the cylinder walls looked good
    There is no water in the oil
    Need advice on how to determine the cause and what possible solutions are
    By the way!! I am not a mechanic
    Thanks to any and all response
    Joe
    Sep 2008
    Maryland - USA
    7,109
    Default Re: KFL valve issue
    Welcome to ME.com!!
    Bummer on the stuck valves....as far as cause, hard to say.....if it wasn't stored correctly, it could just be corrosion.....any idea last time it ran? Any water in the cylinders? around the spark plugs? Any signs of rust occurring in the cylinder bores?
    as far as getting it running, if the bottom end spins over freely, it could be a simple as taking the head to the machine shop and getting them to clean it up. worst case would be to overhaul the whole thing...
  1. 8HP 2004 2cycle Johnson J8RSOR, 1 issue solved, 1 issue remains!
    By johnpol in forum Johnson Evinrude Outboard Forum
    Last Post: 09-22-2015, 07:39 PM
  2. AQ170 Exhaust elbow valve vs no valve?
    By Goodfella in forum Volvo Penta Gas Engine Forum
    Last Post: 06-14-2014, 11:58 AM
  3. Poppet valve issue - 1977 V6 175 HP
    By keviwe in forum Mercury Mariner Outboard Forum
    Last Post: 05-28-2014, 11:57 PM
  4. 1985 150 mag marnier.. the valve next to the poppet valve
    By 150mag in forum Mercury Mariner Outboard Forum
    Last Post: 05-12-2014, 07:20 AM
  5. 1986 3 liter valve adjustment and timing issue
    By jrod1540 in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-05-2008, 02:13 AM
