Jack Daniels
Hello guys. Sorry my first post is a question. I have tried to search the archives and such but can't find a problem similar to mine, so here we go.
I bought a busted bass boat hull with the above motor. Upon purchase/preview the motor was run with a water hose. Starts great and fast, but has a rough idle and runs rough........smokes like a mosquito killing machine. This motor is/was and oil injection. He (guy I bought from) claims the injection unit went out and he had a mechanic remove the unit and plug the proper holes. He says he mixes the oil/gas to a 50/1 ratio. Ok, makes since I have heard of this being done. Motor had good spark and firing on all 6 cyls. Good compression and equal on all cyls. Motor seemed to be sound and it was a great deal, so I bought it.
I'm now at the house trying to figure out the rough run/idle and heavy smoke. I removed the gas tanks from the boat, removed all the old gas and replaced with premium gas at a 50/1 ratio. Runs a little better, but not much improvement. Replaced all the spark plugs. Helped but still rough and heavy smoke. "He" claims the carbs had recently been rebuilt, but I take this with a grain of salt. This model has no carb adjustment scews, factory set with no means of adjustment, or so my research shows and I can't find any screw adjustment.
I have enough knowledge to be dangerous. I think it is running super rich which is causing the smoke and rough running. Could this be the problem? My next step is to remove and clean carbs, reinstall and hope for the best.
Any help or guidance from any of you mechanic types.
Thanks in advance.
Thanks in advance.
