Correction; omc tilt unit
check the drive shaft first , that's the easy one. if that's okay check the hammer blow coupling , you will need to remove the tilt motor to service that coupling
my drive shaft was broken on the end that went into the hammer blow coupling , to service the coupling remove tilt motor it's inside the stern . I highly recommend buying a service manual the seloc manual is only $30.00 well worth the price
