Here goes, hope someone can help. 2003 150hp, carbureted with 525 hours. Recently when coming to idle after a long run I noticed a miss while idling in gear. The miss isn't noticeable in neutral. New plugs didn't help. Compression was good on all cylinders. I'm a retired auto mechanic so I have a lot of experience, but mostly on 4 cycle engines. Thank you , in advance , for any suggestions. Oh yeah, the problem has progressed to where now I need to get above 1700 rpms for the miss to go away. No problem in neutral.
