Hi
I would like some or any advice
I have a gm v8 260b engine in a 24' 1986. 2450 BAYLINER with Volvo 275 sp out drive with a ratio 1.61 I would like to change the lower unit to a 280 290 duel prop can anyone help me try do do this. There are some dou prop lower units for sale on eBay .
i don't know which one can work with mine drive.
I called Volvo and they said it can be done but there is a lot of different ratios that need to be changed
I don't know much on ratios and don't know were to start
i have already rebuilt the upper drive because of leaking seals. So I know about enough to do this type of work . I just need some directions to get it going
I READ ALOT OF FORMS ON THIS BUT COULD NOT FIND ANYTHING ABOUT HOW THE RAIOES WORK IN THE DRIVE WHAT THE PRELOAD TEST NEEDS TO BE. DOES ANYONE HAVE A STEP BY STEP INSTRUCTIONS TO DO THIS
will I need to change anything else Or just GET A D/P lower unit WITH the correct type of RATIO
thank you. Japato11
thank you. Japato11
