Shift Handle broke off leaving just an inch of lever making it difficult to shift.
Purchased a new shift lever, took a week for boats.net to get it.
Have Factory SM and have done exhaust pipe, cylinder head etc., etc., but am stuck now on just removing old shift lever.
I have removed both bolts (shift bellcrank & neutral sensor) and shift rod won't slide out. Plenty of grease in there (no corrosion) and it has moved less than an inch on its way out. I have removed the neutral sensor as well but both 'shaft cams' seem loose enough. I can relieve the pressure on the detent roller spring.
Page 87 on changing to a remote shift lever says
Page 38 shows a "Groove" lengthwise on the shaft, not seen on original or new shaft, just the two quarter-round cutouts for the bolts and a flat spot on last quarter inch.
Do I just need a big hammer to drive it out, or am I missing something?
Wishing I'd just stuck a 3/8" pipe over the broken shift lever stub...
Thanks for any help on this issue,
Art
Their photo has a oval below the shift arm bolt but can't see anything in their oval. I'm guessing they mean what the removed bolt had held tight..."NOTE: If the shift is difficult to remove, expand the shift arm groove with a screwdriver"
Art
