Hi Folks,
we have a 1985 Sun Runner 310. I have pulled to outdrives off to replace them with 2 much better freshwater drives. I was reading an older post and it was mentioned by Ricardo to replace the PDS Bearing which is the engine output shaft bearing in the transom plate/Bellhousing where the shaft comes out. I dont have any history to tell me the bearing was ever changed.
How would I check the bearing to see if it is good or should I just change them?
Do I have to pull the engines to change this bearing?
Thanks,
Kevin
1983 SunRunner 'The Russian Princess"
Thanks,
Kevin
