bent prop shaft
While lower unit is off is there anything else i should look at on part still connected to boat that would cause vibration
Prop shaft probably going in to straighten this weekit tuff due to my work schedule and the distance of the shop to me have put on a new prop and I had the vibration stillnever thought that I will look like that kind of vibration its not even really bad its just when you starting off slow up until you get to plane and then once you're on Plane it good it my first boat so I not even sure if this is normal on some boats.
Update
i still have not had prop shaft straightened yet but i did get all new seals and bearings for the spool it sits in waiting on 1 bearing that should be here today.
One of the bearings in the spool felt like it had a nick or something around edge so im not taking a chance on it
I just picked up the straighted prop shaft polished too.
The shop I went to also was able to customise a 4 blade propeller for me 17 pitch.
Try it if I dont like it they will exchange it no problem.
Great guys over at Bayview Marine Warwick RI.
Class act.
