MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
    Default 1983 Mercury 50hp 4 cylinder
    Help needed if possible, I have merc 50hp 1983. Bought as none runner due to needing trigger assembly. Engine was already stripped.
    I have installed new trigger.
    But unsure of correct flywheel position to crank boss.
    regarding timing marks on fly wheel.
    Also is there a timing mark pointer on engine to do timing off
    any help be great carvey
    Sep 2010
    ontario
    14,161
    Default Re: 1983 Mercury 50hp 4 cylinder
    Was the flywheel itself taken apart ?------Was the flywheel removed as one assembly ?
    Jan 2016
    San Pedro CA
    306
    Find the true tdc using the piston stop method - and work from there.. this is very accurate and u can find your zero mark regardless of fly wheel position..
  1. 1986 Mercury 3 Cylinder 50hp Not Starting
    By imhuntsm in forum Mercury Mariner Outboard Forum
    Last Post: 07-21-2015, 12:10 AM
  2. 1983 50hp Mercury Outboard - Fuel in Cowling
    By Breakerbreaker19 in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2015, 07:33 AM
  3. What is the max RPM for a Mariner (Mercury) 50hp inline 4, 1983/84 motor?
    By jaykmar in forum Mercury Mariner Outboard Forum
    Last Post: 02-08-2011, 09:59 PM
  4. MERCURY 50HP IMPELLER 3 CYLINDER 2 STROKE
    By davidxxx in forum Mercury Mariner Outboard Archive
    Last Post: 07-19-2009, 12:38 AM
  5. Mercury 1983 50 hp outboard 4 cylinder
    By Jim W in forum Mercury Mariner Outboard Forum
    Last Post: 07-09-2008, 10:44 AM
