MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default 1983 Mercury 50hp 4 cylinder
    Help needed if possible, I have merc 50hp 1983. Bought as none runner due to needing trigger assembly. Engine was already stripped.
    I have installed new trigger.
    But unsure of correct flywheel position to crank boss.
    regarding timing marks on fly wheel.
    Also is there a timing mark pointer on engine to do timing off
    any help be great carvey
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,935
    Default Re: 1983 Mercury 50hp 4 cylinder
    Was the flywheel itself taken apart ?------Was the flywheel removed as one assembly ?
  3. #3
    Join Date
    Jan 2016
    Location
    San Pedro CA
    Posts
    328
    Find the true tdc using the piston stop method - and work from there.. this is very accurate and u can find your zero mark regardless of fly wheel position..
Similar Threads
  1. 1986 Mercury 3 Cylinder 50hp Not Starting
    By imhuntsm in forum Mercury Mariner Outboard Forum
    Last Post: 07-20-2015, 11:10 PM
  2. 1983 50hp Mercury Outboard - Fuel in Cowling
    By Breakerbreaker19 in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2015, 06:33 AM
  3. What is the max RPM for a Mariner (Mercury) 50hp inline 4, 1983/84 motor?
    By jaykmar in forum Mercury Mariner Outboard Forum
    Last Post: 02-08-2011, 08:59 PM
  4. MERCURY 50HP IMPELLER 3 CYLINDER 2 STROKE
    By davidxxx in forum Mercury Mariner Outboard Archive
    Last Post: 07-18-2009, 11:38 PM
  5. Mercury 1983 50 hp outboard 4 cylinder
    By Jim W in forum Mercury Mariner Outboard Forum
    Last Post: 07-09-2008, 09:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
