Hello everyone! I would appreciate some input on tracking down an issue on the trim tilt on my 1984 Evirnude 70. Problem is the trim motor will not run at all so I know im looking at an electrical problem. So far I have cleaned and checked all (I think) connections and contacts in the system, checked the fuse, and replaced a few connectors that were corroded. I checked voltage in the relay box on the engine and I have 12.6v on the main power input.(Not sure what its called exactly but its the red wire bolted in the top left corner of the box) The odd part is when I hit the switch I do get some power to the relays, 12mv or so, I was thinking a problem with the switch. I put a jumper between the red and blue wire on the switch with no luck. So, now I am here out of ideas.
