Results 1 to 3 of 3
Thread: 351 windsor
  1. #1
    Default 351 windsor
    I have a 351 windsor engine I changed the distributor cap, rotor ,plugs and wires on the trailer it tachs up over 5000 rpms when I put in the water and put it in gear it won't go over 2000 rpms but does not miss or hesitate any Ideas
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,270
    Default Re: 351 windsor
    Ayuh,..... Check the Contents of the fuel filter for water, 'n crud,....
    Sounds like it's runnin' outa gas,....
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,880
    very possible....could also have lost the timing advance....
Similar Threads
  1. Redline 351 windsor HO
    By lefrog in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 11-18-2014, 07:31 AM
  2. no power omc 235 hp W/351 Windsor
    By bellboy in forum OMC Sterndrive and Inboard Forum
    Last Post: 04-21-2010, 11:28 PM
  3. 351 windsor
    By ecw067 in forum OMC Sterndrive and Inboard Forum
    Last Post: 09-02-2009, 10:53 PM
  4. 351 windsor
    By ecw067 in forum Mercruiser Sterndrive Archive
    Last Post: 08-17-2009, 11:43 AM
  5. 351 windsor
    By fishermanmike in forum Miscellaneous marine engine topics
    Last Post: 07-20-2009, 06:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
