Hello everyone
I am thinking about building a new motor for my 26 FT. HOURSTON
I would be starting off with a marine block that has the one piece rear main.
New pistons D shaped for the quenching effect as per Ricardos recommendation.
Here is my question I am considering using aluminum chev fast burn heads
for increased power.
I will be using closed loop cooling system with heat exchanger
Will the salt air environment cause havoc on the aluminum heads.
Or should I just stay with the cast steel Vortec heads
Thank You in Advance
Cheers
Cheers
