Results 1 to 10 of 10
Thread: Clinton 7hp
  1. #1
    Default Clinton 7hp
    I have been given a Clinton 7hp (K700 5000D) . It came without a top cover or gas tank. I don't Know if it is a Sears or Wards or even if it runs. Any info. on it would be helpful. DAVE
  2. #2
    Default Re: Clinton 7hp
    Quote Originally Posted by smallfarm View Post
    OK question #1 sense it came without a gas tank should there be a female connector on the line to the tank? Will a hose clamped on the male connection on the motor work? DAVE
  3. #3
    I have been trying but have not had any luck uploading to the forum.
  4. #4
    Quote Originally Posted by kimcrwbr1 View Post
    Do you have pics?
    http://s968.photobucket.com/user/lit...m77/slideshow/
  5. #5
    serial # is 860-369
  6. #6
    I'll work on that this weekend. Last weekend I finally got time to look it over better. It is missing the choke adjusting setup. There is a linkage coming from the trans. shifter going towards the carb but connects to nothing. When I pull the starter rope with the trans in forward the prop turns but when it's in rev. it doesn't turn at all. I also get no spark when turning the motor over.
  7. #7
    here are the photos of the gas connector.
  8. #8
    I did some checking today and the coil is dead. If I can't find a good one I'll put it up for sale for parts.
  9. #9
    I've done some more checking. Someone put some die-electric compound in the coil where the spark plug wire goes in. There was enough there to keep the wire from making contact. I should get spark when I get it back together. Now I need to find someone I know with a gas tank to see if it will run.
  10. #10
    I finally borrowed a gas tank from a friend and tried get it started. The recoil broke. The inner tab holding the spring broke off. What a bummer!
Similar Threads
  1. clinton j8
    By Justin Keller in forum Clinton Outboards
    Last Post: 03-02-2011, 08:04 PM
  2. Clinton AJ9
    By labsports1 in forum Clinton Outboards
    Last Post: 04-08-2009, 12:34 PM
  3. Clinton 500
    By fishingbear in forum Johnson Evinrude Outboard Archive
    Last Post: 03-04-2008, 09:22 AM
  4. Clinton 500
    By fishingbear in forum Archive 2003-2009
    Last Post: 03-03-2008, 03:09 PM
  5. J9 Clinton
    By catfisher in forum Archive 2003-2009
    Last Post: 02-10-2008, 04:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
