Hi guys, I am new to the forum but have looked for many years. Thanks for all the input.
I have a pair of Honda bf 150's 2006 they have always run and performed well, they are on my 26 SeaVee center console and I charter out of Cape Cod, Mass.
The motors were purchased new and I now have 2400hrs on them, they run 5600RPM's WOT with a load on the boat. The only alarm I have ever had was a couple of overheat's and the eel grass here was the problem stop back up and fine. Every spring I do all fuel filters, plugs, thermos, clean IAS screens, zincs, drain VST tanks, water pumps and more recently changed the screen under the HP fuel pump's. I have never had any fuel related problems with this setup.
From about 200hrs on, the port motor has started to stall when warm. It is usually random but now has got worse. When flushing on the muffs the port motor runs fine for 10 seconds or so then rpm's drop and it starts to sputter and shake bad. If I turn it off it restarts fine but the same thing happens.
I have read Hornblower's thread SCS codes and it seems as he was having the exact same problem I have. I have done the same thing as him to try to isolate the problem swapping sensors, fuel rails, ECM's, IAC's, Map's, O/2's checked all plugs for loose connections. If I unplug my A/F sensor the motor runs better and smooth but I think that is because the rpm's are up at 850 and it cleans up the stumble.
On the advise of Honda American I checked the crank shaft end play for the thrush bearing problem and they both are tight and well within spec. Compression was even and where they need to be. Drop test was good as well. I run ring free a few times a year and this spring did Dunks method of decarb. When the stumble occurs if I squeeze the primer ball it gets hard and does not change the motor's stumble.
I think the only thing left to do is a valve check but that will have to wait till the end of my fishing season.
I was hoping that someone could give me there thoughts as it's driving me crazy. The motors run great except at idle and stall
Thanks in advance for any input on this...
Josh
Outermost Angling Charters
Josh
