Sorry to hear that. Seems like this would be a good time to also change out the old exhaust tubes IAW Honda Service Bulletin # 56 if it has not already been done. The kit is only about $110 on Boats.Net the last time I looked. If you need a copy of the SB, send me an e-mail at [email protected].
I want to close the loop on my issue:
Update: The root cause of the problem was determined to be a leak in the Case Mount 23170-ZY3-030ZA assy. I was told its a combination of corrosion and damage. I think it got damaged when I replaced the water pump. But probably would have been OK if it wasn't corroded/compromised in the first place. The total bill "Estimate" will be ~$2,100 total, labor $900 and $1,200 in total parts.
PS: The main title thread should Read "2004" instead of 2001. I can't correct it, can a thread monitor fix that?
Hey Seachaser, I have the same motor with the same leaking oil spot . Could you please send me a contact info so I could ask a bunch of questions? I just bought this motor off a used outboard dealer in Stuart. It was supposed to be good, it runs good but leaks in the same place as yours. Great post!Thanks Chawk, I have the manual and will check that out
Hey Seachaser, I have the same ßmotor with the same leaking oil spot . Could you please send me a contact info so I could ask a bunch of questions? I just bought this motor off a used outboard dealer in Stuart. It was supposed to be gofod, it runs good but leaks in the same place as yours. Great post!
Where did you take the motor to be fixed?
Would you do the repair again knowing what you now know? (I have some shop experience but not sure how deep of a job I want to go here.)
Do you know if any special tools were needed?
What parts did you replace in total? Have part numbers?
How many hours did the shop bill you for?
What would you change if you were to do this again?
Please e-mail or reply, Many thanks in advance!!!
Respectfully, Fleatools...
