Results 1 to 2 of 2
    Sep 2008
    pensacola, fl, us
    186
    Default Hurth zf 63 recommended pressure
    1995 Hurth ZF 63 C (HSW 630 V1) connected to 95 Crusader 454xl's. What is the pressure suppose to be?? At 3000 rpm, on plane, the VDO gauges read 225 psi on stbd and 185psi on port. I looked in the manual and all it has is "shifting pressure" in the 'adjustment data' section. It says 325 psi. My gauges only go to 400psi!
    Sep 2008
    Maryland - USA
    7,398
    Default Re: Hurth zf 63 recommended pressure
    I'd be inclined to check the pressure readings with a mechanical gauge before getting worried.....I don't think my velvet drives make that much pressure....
  1. Hurth zf25
    By Malaya in forum Marine Transmissions and Reverse Gears
    Last Post: 08-05-2014, 12:31 PM
  2. ZF Hurth tranny noise need help.
    By Floatation Device in forum Marine Transmissions and Reverse Gears
    Last Post: 11-10-2010, 12:57 PM
  3. Hurth V Drive
    By kevin_z in forum Crusader Marine Engine Forum
    Last Post: 04-29-2010, 09:53 AM
  4. Cheaking oil on hurth transmission
    By lugnutdan in forum Crusader Marine Archive
    Last Post: 06-10-2009, 09:26 PM
  5. Hurth V Drive
    By DavidJensen in forum Archive 2003-2007
    Last Post: 08-24-2002, 02:49 PM
