Barry Prior
I am a car mechanic for 25 Yrs so have great mechanical skills but only on 4-Stroke. Never toutched a 2-Stroke EVER.
Got the engine running good now thanksto you guy on here with nice and low idle but now have another problem
I have a problem with the Tell Tail not producing enough water. I have stripped the pump section and found the rubber impeller to be knackered/faulty. Great I thought....... but when cleaning out the water ways with the hose from the tell tail, backwards I have found that the water seems to be going into the exhaust system and not directly out through the bottom. When I blow up the telltail I can hear the blowing through the top exhaust vents and when I put the hose up the water inlet as I have removed the propeller/Water pump bit the water dosn’t even get to the top of the engine to come out of the tell tail outlet. Ouch I am thinking please could you advise weather is it worth stripping the exhaust plates.
07748 655731 London UK
