Results 1 to 5 of 5
    Default cankshaft sensor fault code troubleshooting Indmar 388 hammerhead 2007
    This forum was great when I had an 88 volvo penta.
    Last year I bought a 1997 malibu with the Indmar 383 Hammerhead engine. I runs fine till about 3500 RPM them hesitates or misfires, won't accelerate and the check engine light comes on.
    My marine mechanic replaced the plugs, distributor cap and rotor while waiting for the engine diagnostic scanner with no change in peeformance. When he finally got a scanner it indicated a "crankshaft sensor fault" he then ordered and changed the sensor with no change in the performance and the same fault code comes up.
    The mechanic spoke to Indmar who said that the next step would be to pull the engine and check the Reluctor ring.
    Before i have the huge expense of pulling and opening up the engine, are there any other ways to check if this is indeed is a Relutor ring problem or other component failure that is related to misfiring/hesitation???
    The boat continues to start easily and run fine at lower RPMs/ speeds. I have not missed a day on the water this summer and have put on about 100 hrs pulling wakeboarders and towables without a problem as long as the RPMs are maintained below 3000-3500.
    Sep 2008
    Maryland - USA
    6,839
    Default Re: cankshaft sensor fault code troubleshooting Indmar 388 hammerhead 2007
    so the engine has a MEFI-4 ECU? Just an observation but I'd be inclined to get another mechanic based on your third sentence as that one's troubleshooting skills are lacking (though his business strategy appears optimized to fatten his cash flow)....
    Was code 81 (DTC) set??
    Quote Originally Posted by makomark View Post
    What do you mean by "was code 81 (DTC) set"??
    thanks
    Sep 2008
    Maryland - USA
    6,839
    when the scanner was hooked up to the ECU, was a DTC of 81 present?
    I really don't know.
    why do you ask?
  1. Indmar 383 Hammerhead CYL Head replacement options
    By buick430 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 08-11-2016, 10:41 PM
  2. '06 BF225 ECM fault code
    By SpearoDude in forum Honda Outboard Forum
    Last Post: 09-09-2013, 04:24 PM
  3. Unusual fault code on DF150
    By Sol in forum Suzuki Outboard Forum
    Last Post: 12-09-2012, 12:02 AM
  4. DF 70 Fault code 32
    By torque in forum Suzuki Outboard Forum
    Last Post: 11-10-2009, 06:07 AM
  5. SC5000 fault code
    By quijibo in forum Mercruiser Sterndrive Archive
    Last Post: 05-26-2008, 11:32 AM
