Hello All,
I am working on a 1995 Force 90 Hp S/N OE104323 and I have a few questions.
1. How is the primer system supposed to work? Is fuel injected into the intake manifold just past the carbs? Is fuel injected at each carb?
2. I have a leak at the carb/intake mount when I prime the engine. It is just a drop or two but if it leaks fuel it will suck air. This leak is on the center and lower carbs. Is this typical of this motor? I have never seen an outboard leak like this unless a gasket is messed up. Please advise with your thoughts on the leak.
Thanks in advance for your help.
rcb130
rcb130
