Starter solenoid
tstadulis
Are there obvious first steps
Are there obvious first steps in diagnosing the reason why a starter solenoid would burn out? The battery is fully charged.
" Stsrter solenoids are like a
" Stsrter solenoids are like any other part, that is they all wear out. If you are having repeated failure of the solenoid, you may have a loose connection, inadequate wire size or even a moisture problem. Electrical components hate water or moisture (dripping cooling hoses, etc). Good luck and hope I helped. Kim "
