Results 1 to 2 of 2
Thread: ted willams 7.5
  1. #1
    Default ted willams 7.5
    I have changed float and plug and rebuilt carb and new spark plug it still wont start and replaced element I keep pulling and nothing its in water now gas leaks out the bottom can anyone help me out techusma t 630-038 or 6974321 is written on it I also bought 93 gas and sea foam added it and 2 cycle oil ration 40-1 still nothing
  2. #2
    Default Re: ted willams 7.5
    I'd start by taking the float bowl back off and seeing what's causing the fuel leak, it's likely just the gasket on the bolt that holds the bowl on. Next, make sure the bowl is orientated correctly so the float can sit in the lowest part of the bowl. I'm assuming you pulled the spark plug to see if it was wet with fuel and tested for spark?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
