followingsea
Here's the overview. Been fine tuning my little AQ 140 with Weber carb. Went through and adjusted the valve clearances. Got them all about where I wanted them. Took the boat out the other day for a fishing trip. I ran about 10+ miles mostly cruising at 3,800- 4,000 rpms--when not idled down or running slow. Ran it up to 5,000-5,200 for maybe 5 seconds a few times to be sure I had my prop dialed in the way I wanted it-- with a load and all.
She ran great the whole trip--all the way back to the trailer.
This morning I decided to do another check of my valve clearances. Most of them were in range (cold) except one, I could easily slip a .030 gauge under the heal of the cam. It was .016 when I checked it previously.
I doubled up two gauges and could slip .040+ under the heel of the cam lobe! Then I noticed what was happening. Each time I put the gauge under it seemed like there was very little tension on the valve spring. The little cup that holds the shim just moved downward too easily.
I had some extra shims so I re-shimmed it with one about .20 mm bigger, trying to take up the slack. It made some difference but it was still way too loose. The spring (with cup and shim) still moved downward with just a little resistance.
Is this a "weak" spring? A broken spring? What's the best way to diagnose this? Frustrating. I was just doing the last little adjustment to get those valves "just right"-- then this.
Compression is great on all cylinders (165-170 psi). The motor has about 450 hours on a complete rebuild. I'm thinking of just leaving the head on, pulling the camshaft, pull that particular spring out and replace it with a used spring from one of my "parts heads". Or should I pull the head and replace all the springs now?
Suggestions?
Suggestions?
