BigJim1943
Does anyone know exactly how the float is to be adjusted on the 85 hp. I know the float has to be level but does the bottom of the float have to be up even with the rim of the carb or can it sit down inside a little?
Unless someone has manipulated the float arm, it should be just fine and then just set parallel with the carb body. Be sure to not press down on the needle when adjusting, as this may cause damage to the soft needle tip.
The " racing " of the motor has nothing to do with the floats.-------Check for throttle plates being open or timer base being to far advanced.---------Do you have a model specific FACTORY manual ??----------I have worked on more than one of these carburetors and have never had issues with floats that meant bending like you mention here !!!
Have you checked spark with a spark gap tester? could be the trigger or the PP, what two cylinders were not burning? Swapping parts only works if you have known good parts. You need a DVA adaptor to properly test the ignition system.
You can make a spark gap tester or just buy one it must jump a open air gap of at least 7/16 inch with a brite blue snap on all four plug wires. Disconnect the yellow wires and check spark gap. You can just stick a screwdriver in a plug wire and hold it about 7/16 inch from a bare bolt on the head, just be careful it will knock you on your ass if you get bit. have someone turn it over for you unless you have a remote start button. You will definately need to get it into sync also but focus on getting good spark first. I cant remember what are the compression numbers. That is allways the first step in diagnostics.
I converted my ford pickup to a duraspark ignition from the TFI and went to mess with the tranny vacuum line next to the distributor. The TFI coil will jump a 7/8 inch gap, my hand didnt get bit but where I was leaning on the truck is where I got zapped. Use your imagination I never get close to the plug wires when the engine is running.
