Mercruiser horn warning
KTG
I have a 1995 bayliner 2355 ciera with a mercruiser engine
when i crank up the boat the (warning horn) comes on and don't go off.
I check the oil level and it is good.
The engine temperature is not going up or running hot (water level is good )
the drive lube was a litter low (so i top it off) waited a few min and still continue to go off
*****the boat will crank up and run with no problem . I just don't want to take a chance damaging something or making it worse .
I have read /seen that it will also go off if the batters is low ( will go get them and charge them and see if that will work .
Until then i would love some help / feed back if that does not solve the problem
thank you
