Results 1 to 4 of 4
  1. #1
    Lightbulb Replacement of Volvo TMAD41A .
    I need to either do a rebuild on a Volvo TMAD41A engine, or find a replacement diesel engine for our skiff.
    rebuilding is somewhere over 20000.00...The engine fare market valve (Old Engine) is around 6000.00.
    I would like to stay away from outboards /gas if possible.
  2. #2
    Default Re: Replacement of Volvo TMAD41A .
    At 20,000 you must be doing much more than cylinder kits. In any event what is the application of the vessel? Commercial? Pleasure?
  3. #3
    Coastal Marine in Seattle wants over $20K for a complete rebuild, total reman, engine tore down to the last piece, when you get it back it looks like a new engine. I know this because I have talked to them about rebuilding my 41a's. Parts alone is a minimum $5,000. Liner kits are $700 each, the pistons are a better design to reduce smoke, 41a's are known to make smoke when not up to operating temp.
    I would love to replace these with a different brand but I'm not having much luck finding choices.
    oottomc do you have a reduction gear or an outdrive? When you say "skiff" it makes me think of a small seine skiff.
    I have a 36' aluminum bowpicker and one of the likely swaps has been YANMAR .
  4. #4
    Also the flywheel housing on a 41A is a SAE #4
Similar Threads
  1. Volvo Penta MD6A replacement
    By Dave Tripoda in forum Volvo Penta Diesel
    Last Post: 09-16-2011, 01:10 AM
  2. Volvo penta mb2/50s replacement engine
    By René Côté in forum Volvo Penta Gas Engine Forum
    Last Post: 07-11-2011, 10:55 PM
  3. Volvo BB 70 AQ 80 Replacement
    By stu_stumble in forum Volvo Penta Gas Archive
    Last Post: 03-30-2007, 09:49 AM
  4. Replacement for Volvo Penta 2002
    By Seth Kunin in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 03-09-2006, 01:38 PM
  5. 43 volvo GM marine replacement block
    By Charles Lail in forum Archive 2002-2006
    Last Post: 04-19-2002, 11:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
