SLow trim
If the motor sounds weak, it could be bad relays, motor, or bad connections on wiring that just need a wire brushes attention.
If motor sounds good, could be a leak in seal, low fluid, water in fluid, or air in system.
Slow up and down?
Slow up and down?
Motor sounds good....goes up just fine...comes down good until it gets to the trim at which point it goes very very slow
Try bringing your motor all the way up, lock it, loosen the manual release screw, manually lower and raise your motor a few times, then tighten screw back up with motor up.
