Results 1 to 5 of 5
  1. #1
    Default can i change the AS1 71C to work for either standard or counter rotation?
    I have a 72 Bertram 28' twin inboards. I was told they are 351 Windsor Fords. But the plate I found says 302(is there an easy way to confirm which it is ). My real question is how simple is it to reverse the oil pump? I want to put a standard rotating motor in where the counter rotating was? I've heard this is all I need to do to make reverse become forward and vice versa? Is that correct?
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,397
    Default Re: can i change the AS1 71C to work for either standard or counter rotation?
    to reverse the pump, you just remove the four bolts and rotate the pump body so the "input rotation arrow" points the same way the flywheel rotates.
    You don't want to get "Forward rotation" with the gear selector in the Reverse position....
    you might wanna check with your local gear shop to see if this is viable....I suspect the output will spin backwards but not sure. If you don't have a shop local, call Hale Marine - they specialize in velvet drives and have been around for decades....
    On the 302 vs 351, not being a ford guys I cant say definitively but I'd suspect you can check the casting numbers on the block to verify what it is....any good machine shop (or an internet search) will tell you where to look....If they started life as marine engines, there should be a serial number ....
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,397
    Curiosity got the best of me...so I went and looked it up....
    It won't work as you want it to. If you switch the rotation of one of the engines, and reverse the VD pump housing, the propeller's rotation will be reversed (in other words, the gear rotates the same as the engine while in forward).
    I think it would be most economical to have the engine rebuilt to the original rotation or, if you already have it, get it reworked to spin 'backwards'....just my two cents
  4. #4
    Quote Originally Posted by FJT2448 View Post
    Ok, what I was told is it's not ideal because the trans will be using an extra gear constantly, but it will work. With the many rebuild kits out there, can the trans be switched? So it will be in forward with the standard rotating motor? Or do I need a different trans altogethe? The only new ones I saw were 1:1 not the 1.5:1.
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,397
    Not sure where the extra gear enters this.....
    You'll need a different gear altogether if you want to use the LH engine where the RH was...a 'full power in reverse' type....like a VD5000 or a ZF
Similar Threads
  1. Need to change a Gen4 454 from reverse to standard rotation
    By Whttnbrg in forum Mercruiser Sterndrive Forum
    Last Post: 11-26-2012, 07:15 PM
  2. Counter vs. standard rotation 1990 454
    By contender31 in forum Crusader Marine Engine Forum
    Last Post: 12-06-2010, 09:09 AM
  3. Converting to Standard Rotation Distributor Change
    By georgeinbeverly in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 08-13-2009, 01:39 AM
  4. Change Engine from Reverse to Standard rotation
    By linesix in forum Mercruiser Sterndrive Archive
    Last Post: 11-21-2006, 02:55 PM
  5. 1975 ford marine 302 standard and counter rotation
    By Brian Keiner in forum Archive 2002-2006
    Last Post: 03-13-2004, 11:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
