Results 1 to 6 of 6
  1. #1
    Default Volvo penta 290 dp
    Hi guys I have a Volvo 290 dp out drive 2.30 ratio I need 1.78 ratio to connect to a Volvo kamd42p(230hp) do I have to change the upper gear or the lower unit gear? Thanksssss in advance
  2. #2
    Default Re: Volvo penta 290 dp
    It's all in the lower unit.
    Just do a search on ebay for "Volvo Penta 290 lower unit" ,
    it will show lower units with different ratios listed.
    Any future Volvo Penta questions will get better results if you post
    in that forum , it is an active forum with lots of knowledge.
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,703
    There's one exception to this....... and that would be the "E" drive!
    Look at your PZNR tag on your transmission, and see if it lists "E".
    The "E" transmission gear reduction is greater than all standard ratio transmissions.
    For example...... with the "E" drive, a 1.78:1 lower unit gives us a total reduction that's close to 1.95:1.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    thanks RICARDO for your answer I Really appreciate it thanks
    Quote Originally Posted by RicardoMarine View Post
  5. #5
    I'm intrigued by the "E" drive. What engine(s) would that have came with?
    It is a 290? What lower unit ratio(s) came with the "E" ? What years?
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,703
    Quote Originally Posted by CASTLE_CAPE View Post
    The E drive was a Diesel Engine drive...... and was a later series from the 290 series.
    The E transmission further reduces the reduction so that a different combination of lower gear sets could be used.
    Here's the deal with I/O lower unit gear sets:
    The further the reduction, the smaller the "drive" gear ("pinion" gear in the Auto world), and the larger the "driven" gear ("ring" gear in the Auto world).
    As the reduction becomes greater, there is less gear tooth contact at any given time.
    This equates to a weaker gear set that is more prone to breaking under heavy loads.
    So...... in order to accomplish an over-all ratio of let's say 2.30:1 (the 2.30:1 lower gear set being the weakest), the E transmission is used with a 1.95:1 lower gear set (a stronger gear set).
    This combination gives an over-all reduction of 2.30:1, or very close to it.
    Likewise, in order to accomplish an over-all ratio of let's say 1.95:1, the E transmission is used with a 1.78:1 lower gear set (a much stronger gear set).
    This combination gives an over-all reduction of 1.95:1, or very close to it.
    In order to accomplish an over-all 1.78:1 reduction, the E transmission would not be used.
    Portland, Oregon
Similar Threads
  1. Volvo Penta AQ150B | Volvo Aquamatic 250B
    By PCP in forum Volvo Penta Gas Engine Forum
    Last Post: 05-25-2016, 11:14 AM
  2. Help with Volvo Penta AQ140 / Volvo 280 outdrive
    By IronWolf in forum Volvo Penta Gas Engine Forum
    Last Post: 08-15-2010, 04:37 AM
  3. Volvo penta 280 value
    By 92banana in forum Volvo Penta Gas Engine Forum
    Last Post: 12-17-2009, 08:57 PM
  4. 1996 Volvo Penta 57 GI EFI with Volvo Duo Prop
    By joshdenton in forum Volvo Penta Gas Archive
    Last Post: 05-28-2009, 10:19 AM
  5. 1964 Volvo penta AQ180 Volvo B36B engine
    By hystat in forum Volvo Penta Gas Archive
    Last Post: 05-01-2004, 05:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
