Problemsolved !! CaboJohn was closest to themark suggesting fuel starvation. Apressure gauge teed into the carb fuel line told the story. Upon start had 7 psi – on spec. At 3500 rpm maintained 6.5 psi for aboutthree minutes and then began to slowly decrease. At 2 psi the surging started until Ithrottled back to 3000 rpm and the pressure rose to 5 psi. Thought the problem may be the fuel pump butdelayed taking the bait until more testing was accomplished. Attached a volt meter to the fuel pump CB anddiscovered the voltage dropped as the pressure dropped. Then attached two voltmeters to the fuel pumppower supply wire; one before and one after the oil pressure switch. As I bended throttles on the bridge my FirstMate reported pressure and voltage readings from the engine room. She reminded me of Mister Scott, “ Aye Kaptan, that’s all she can take cause she can’ttake no more”. No kidding, she wasawesome! Voltage to the switch remained at 13 volts while voltage out startedat 13 volts but slowly decrease to 4 volts. Pulled back the throttle to 3000 rpm at the surging onset and the voltagerose to 10 volts. This seemed to clearlyconfirm my one year old $110 oil pressure switch was defective. Finally, real progress in solving theproblem. Changed out the oil pressureswitch and motored out for what I hoped would be the final test run. Bothengines spooled up like a pair of J79s and never missed a beat. When I was convinced the problem was solved, Icut donuts in the calm waters of Choctawhatchee Bay, overwhelmed by theeuphoria. The clue bird had landed and Iwas Neil Armstrong, the 3500 rpm barrier was broken and I was Chuck Yeager – I couldgo on but I think you get the picture. Myyear-long nautical nightmare was over !! I motored triumphantly back to the marina and envisioned fire boatsputting up red, white, and blue arcs of water saluting my technicalaccomplishment. A little over the top,but it was a rough year and, what the hell, it was my vision. I later searched all the car and boat forumsand did not find another instance of the gradual switch failure I hadexperienced. My initial suspicion thatan electrical component was overheating and failing under the thermal burden provedto be correct, however, I was concentrating on the wrong system. The first fork in the troubleshooting decisiontree is the question – is it spark or is it fuel ? New water seps, filters, year old fuel pumpand pressure switch, fresh ethanol-free fuel, clean vents, no anti-siphonvalves, problem occurring with main tank, saddle tank, both tanks selected ,problem happening only after warm up – all suggested problem was spark and notfuel. As the old knight in The LastCrusade said, “He chose poorly”. I spentevery weekend of the summer toiling under the Florida sun wringing out theignition system which proved to be fully functional. As myeyeglasses pooled with sweat I envied the young studs having a blast on the waterwith their 18-foot runabouts and young honeys clad in bun-flosser bikinis – butI digress. The real lesson learned istroubleshooting must be thorough and the temptation to randomly change partsshould be controlled. It took a longtime to solve but I learned much about the Crusader ignition and fuel systems,and feel good about not resorting to a professional parts changer. Thanks to all the forum members who providedmuch good advice and insight – truly an excellent resource. Fish - be aware that I am back !!
FL Panhandle
