Click for Ford Lehman manuals!
Results 1 to 3 of 3
  1. #1
    Default Injector removal advice
    I want to have the injectors on my Lehman 135 checked. I would like to remove and reinstall them myself. Any advice on how to do this and what to look out for? Thanks
  2. #2
    Default Re: Injector removal advice
    Hi, stuff rags around all pushrods so nothing will fall into places they shouldn't be. Remove returnline on top of injectors and fitting where it joins head. There may be copper washers under the return line bolts and easy to lose. Remove two injector hold down bolts, then put socket wrench on top of injector nut-- turn 1/4 inch clockwise than 1/4 ccw. Should break injector free. After removal look at injector tip for copper washer. Any missing washers are still in the head!!!
    Charlie w.
  3. #3
    Sounds pretty straightforward. Appreciate the step by step advice.
Similar Threads
  1. AD41P removal - rusted oil pan - advice please
    By Chief 915 in forum Volvo Penta Diesel
    Last Post: 03-16-2012, 10:57 PM
  2. Injector Removal Yanmar 3GM
    By lancer36 in forum Yanmar
    Last Post: 09-30-2009, 11:34 PM
  3. Removal of oil injector 95 intruder
    By hydrabass in forum Johnson Evinrude Outboard Archive
    Last Post: 10-03-2008, 06:44 AM
  4. AQ145B290 leg transom shield removal advice
    By daveed in forum Volvo Penta Gas Archive
    Last Post: 11-08-2007, 01:41 PM
  5. Governor Injector Injector pump service tools for V1271
    By sailmaster in forum Detroit Diesel
    Last Post: 06-06-2006, 04:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
