Results 1 to 3 of 3
  1. #1
    Default hole shot problems
    I have a 95 20ft javelin single console with a 95 200hp venom on a manual jack plate. The boat will run 67 at around 5000-5200 rpm but is bad slow coming out of the hole. It has a 25 pitch 4 blade renegade bass prop on it currently. What would be the best choice of prop to pick up on hole shot without sacrificing to much top end? Thnks for all input.
  2. #2
    Default Re: hole shot problems
    OK so i have done some research and am wondering if anyone has had any experience with a piranha interchangeable blade prop. I'm thinking on buying one to find the proper pitch on my boat because it would be a lot cheaper than buying a new stainless prop to test with. any input is much appreciated.
  3. #3
    Join Date
    May 2011
    slough ,berkshire uk
    piranha props are crap.
    they bend more than an alloy prop and are weak.
    You have the right type of pop st too big in pitch by the sound of it. try to borrow a smaller pitch of same type prop.
    or vent the pop hub, 3 vents of 1/2 inch diameter will make it hole hot like a 21 pitch, once on plane will revert to same as now.
    Jut drill the hub like a vengeance prop.
    it really doe work good for faster hole shot.
Similar Threads
  1. Yamaha 130 hole shot?
    By bel-ami 2 in forum Yamaha Outboard Forum
    Last Post: 01-26-2015, 12:34 AM
  2. 84 150 slow hole shot.
    By sermax in forum Mercury Mariner Outboard Forum
    Last Post: 09-21-2014, 10:40 PM
  3. 2002 130 honda hole shot
    By kenlar1 in forum Honda Outboard Forum
    Last Post: 06-09-2013, 09:59 AM
  4. Slow hole shot
    By dtwolcot2 in forum Mercruiser Sterndrive Forum
    Last Post: 10-16-2009, 04:25 PM
  5. No hole shot
    By matt91115 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-23-2006, 08:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
