I have a 1983 80 hp 4 cyl sn 07204275
Using screwdriver to test depth in cylinder 1, I have confirmed that the timing pointer and marks line up with TDC ( +/- 5%) since I can't be precise.
I have good spark on each cyl ( jumps ¼ in gap).
And confirmed with timing light that each cyl is firing at proper time.
I did static timing adjustment andI set timing according to what was written on motor (idle at 4 Atdc and max at 30 Btdc-cranking). Went to try in water but would not start at those setting.
Back home, while on Muffs, I manually played with throttle and timing until I found position that motor would start and idle. I found throttle just slightly ahead of carb pickup( a bit high ) and timing at 10-15 BTDC.
Your thoughts on either of these issues? (related/unrelated) any other ideas
- I'm thinking that my Timing pointer may be off and will need a dial gauge to verify.
- If this is the case..then My Max advance would also be set low, but the adjustment screw is already quite low and not sure if I can advance any more.
- I also feel that My idle seems to be a bit high and 1 turn to the throttle idle position screw will either stall or Rev really high.
- Due to stuck/dirty needle valve…I recently replaced the valve seats, valve and floats. I cleaned the carbs(soaked in seafoam followed by compressed air). I also replaced all fuel lines and added inline fuel filter. I believe all fittings are tight but when I squeeze bulb it gets hard but If I continue to apply firm pressure it will slowly squeeze…I do not see/smell any gas not sure where it might be going. I was thinking that an Air leak in fuel line might cause a lean mixture and might the high idle and high throttle position. The Carb idle needle is turned a full 2 turns as it won't start at 1 ¾ but once started I can turn from 1 ½ to 2 ¼ without any noticeable difference to idle speed. It will stall when reduce to 1.
