Results 1 to 3 of 3
  1. #1
    Default MW Sea King 7.5h wont stay running
    Hello I'm new to the forms from Michigan and am looking for information on a Montgomery Wards sea king 7.5h.
    According to the information I found this is a 1976 made by Clinton. Issue is it will run and start but once in the water it wont run up or idle just stalls out. Having issues with the choke knob not engaging/disengaging and possible carb float issue. Does anyone know where i could find parts for this and does anyone have any manuals for this motor?
    thank you
  2. #2
    Default Re: MW Sea King 7.5h wont stay running
    Quote Originally Posted by buck119fa View Post
    thank you
    I have a 9.9, when I first bought it, it acted the same, new points fixed it right up. Try E-bay for manuals, I got one there and also for for the points the points or an older boat repair shop.
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,360
    Give discountmarine a call they may have a manual. Have you checked the compression? It is basically a two cycle lawn mower motor the choke is only for cold starts. Exactly how are you adjusting the slow needle?
Similar Threads
  1. 318 wont stay running
    By Drfeno in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 09-04-2016, 10:28 PM
  2. 66 3hp wont stay running
    By blhotrod in forum Johnson Evinrude Outboard Forum
    Last Post: 03-08-2012, 06:23 PM
  3. engine wont stay running
    By searay123 in forum Mercruiser Sterndrive Forum
    Last Post: 04-16-2010, 04:10 PM
  4. WONT STAY RUNNING
    By stevewat in forum Mercruiser Sterndrive Archive
    Last Post: 10-20-2007, 04:31 PM
  5. Wont stay running
    By mike wendel in forum Johnson Evinrude Outboard Archive
    Last Post: 05-27-2006, 06:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
