jakefreese
Howdy Guys,
I found my way over here via Google.
I have a 1993 Wellcraft Excel 18SX with the 2.3l Volvo Penta 230A/SP CD. It has the Solex 44 PA1 carb. I recently rebuilt the carb due to it stalling at idle when at operating temperature and not restarting until it cooled some. Pulling into the dock was the big place it would do it, as your shifting in and out of gear.
The carb was full of crud, I rebuilt it and got it back on. Now it will idle at 1600~ rpms and I can not get it to slow down and stay running. I have set the idle and idle mix per the book. Newer style carb, 2 turns after touching the plate on the idle and 8 turns out on the mix screw. Running the mix screw in after starting will not result in a change to slow it down. It will run good above the idle range, you can see it bubbling fuel from the center stem in the carb at idle. I am going to work on it more this evening as I want to put it back in the marina Friday night! Any ideas of where I may have made a mistake or missed something? Almost seems like the main jet is not shutting off at idle ( I had a motorcycle carb with a worn/damaged needle that did that in the past)
Thanks guys! Oh yeah I have not verified timing yet, but I figured this was a fuel problem at the moment. I do have a electronic ignition module on the way to get rid of the points.
