MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
  1. #1
    Default Mercury thunderbolt 500 output shaft oil seal change-help!
    Attempting to remove the cover to replace the output shaft oil seal (on bottom of engine)
    im having trouble removing the actual cover, it's come out about 15 mm but doesn't seem to want to move any further....
  2. #2
    Default Re: Mercury thunderbolt 500 output shaft oil seal change-help!
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,657
    If you are talking about pulling the prop shaft out, use the propeller as a puller; stick and some plywood between the prop and the housing, and tighten the prop nut.
    Jeff
  4. #4
    Thanks for that jeff but I'm actually talking about the output shaft that goes into the bottom of the engine
  5. #5
    Join Date
    Sep 2003
    Location
    Posts
    15,657
    That's the crankshaft.
    The lower bearing cap can be pulled down to remove the seals. You need to loosen the bolts holding the crankcase together and pull the cap down.
    Jeff
Similar Threads
  1. Transmission output seal leaking - post rebuild
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 06-25-2014, 06:15 PM
  2. Mercury Prop Shaft Seal
    By minnguy32 in forum Mercury Mariner Outboard Forum
    Last Post: 04-15-2014, 01:08 PM
  3. Borg Warner v-drive output shaft seal leaking
    By fiveoclocksomewhere in forum Crusader Marine Engine Forum
    Last Post: 03-24-2013, 03:44 PM
  4. 2000 Suzuki DT115 Need to change prop shaft oil seal
    By keng in forum Suzuki Outboard Archive
    Last Post: 07-15-2008, 05:57 PM
  5. Mercury 200 outboard drive shaft seal problem
    By garym23 in forum Mercury Mariner Outboard Archive
    Last Post: 05-09-2008, 10:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
