ShantyBay Tim
Does anyone have an opinion on bulb priming position ? what I know is that the bulb must have the arrow pointing towards the engine , but what about bulb pointing up vertically ? not down or horizontal.
Tim
Tim
My opinion is the arrow should be pointing up vertically for best results. You can try for yourself, priming an engine pointing the arrow down vs up. It may not seem much different after fuel is already through the hose, but if the hose is dry and you are starting from scratch, the check balls in the bulb are set to work best vertically up. So...if the primer bulb to wont get hard, try holding it vertical and unless there is an issue on the motor, it should get hard real fast.
In the ideal world, you should keep the bulb in that vertical position all the time. Most of the time, it can not be accomplished easily. The next best position for running the engine, then, will be laying horizontal, after you squeeze the bulb, holding it vertical.
Try not in any case to let the bulb sit with the arrow pointing down. It is possible for the check balls to not work properly and could actually restrict the flow of fuel.
While we are talking bulbs, the best bulbs on the market, in my opinion, are made by Evinrude/Johnson. I have had customers "save" money, by buying the ones at Walmart. They do not last.
That is my opinion.
Mike
