I have a 1987 Mercruiser 165. I have replaced everything possible on the electrical side. New distributor(points), coil, plugs, wires, converted to an alternator, New battery, new hot battery cables etc..... have also replaced fuel pump, rebuilt carburetor, replaced fuel lines, fuel filter, etc. Thermostat, flushed cooling system, new sending unit, etc.... The engine runs like it is new...until it warms up. Thermostat says she is running at about 150 Degrees on the water side. After 25 minutes it starts to spit and sputter, then dies. Let it cool off for about and hour and it starts up and runs great again until it gets hot. I am looking for some help. I was told it could be a short, as well as it could be on the power side. The coil does get pretty warm. I have 12.58 volts at the battery and about 10 at the coil. The alternator is charging at about 13.4. It is a one wire 68 amp marine alternator. I am at wits end and ready to give up!! Any suggestions
